AM26LV31E,pdf(Low-Voltage High
消耗积分:2 | 格式:rar | 大小:791 | 2010-09-03
贾熹
分享资料个
The AM26LV31E is a quadruple differential line driver with 3-state outputs. This driver has ±15-kV ESD (HBM and IEC61000-4-2, Air-Gap Discharge) and ±8-kV ESD (IEC61000-4-2, Contact Discharge) protection. This device is designed to meet TIA/EIA-422-B and ITU Recommendation V.11 drivers with reduced supply voltage.
The device is optimized for balanced-bus transmission at switching rates up to 32 MHz. The outputs have high current capability for driving balanced lines, such as twisted-pair transmission lines, and provide a high impedance in the power-off condition.
The AM26LV31EI is characterized for operation from –40°C to 85°C.
评论(0)
发评论
下载排行榜
