TL026,pdf(Differential High-Fr
消耗积分:3 | 格式:rar | 大小:514 | 2010-09-27
131594
分享资料个
This device is a monolithic two-stage high-frequency amplifier with differential inputs and outputs.
Internal feedback provides wide bandwidth, low phase distortion, and excellent gain stability. Variable gain based on signal summation provides large AGC control over a wide bandwidth with low harmonic distortion. Emitter-follower outputs enable the device to drive capacitive loads. All stages are current-source biased to obtain high common-mode and supply-voltage rejection ratios. The gain may be electronically attenuated by applying a control voltage to the AGC pin. No external compensation components are required.
This device is particularly useful in TV and radio IF and RF AGC circuits, as well as magnetic-tape and disk-file systems where AGC is needed.
评论(0)
发评论
下载排行榜
