TPS40200-HT,pdf(Wide-Input-Ran
消耗积分:2 | 格式:rar | 大小:914 | 2010-10-05
分享资料个
The TPS40200 is a flexible nonsynchronous controller with a built-in 200-mA driver for P-channel FETs. The
circuit operates with inputs up to 52 V, with a power-saving feature that turns off driver current once the external
FET has been fully turned on. This feature extends the flexibility of the device, allowing it to operate with an input
voltage up to 52 V, without dissipating excessive power. The circuit operates with voltage-mode feedback and
has feed-forward input-voltage compensation that responds instantly to input-voltage change. The integral
700-mV reference is trimmed to 2%, providing the means to accurately control low voltages. Clock frequency,
soft start, and overcurrent limit each are easily programmed by a single, external component. The part has
undervoltage lockout, and can be easily synchronized to other controllers or a system clock to satisfy sequencing
and/or noise-reduction requirements.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
