TLC5971,pdf(12-Channel, 16-Bit
消耗积分:5 | 格式:rar | 大小:817 | 2010-11-02
申根换
分享资料个
The TLC5971 is a 12-channel, constant-current sink driver. Each output channel has individually adjustable currents with 65536 PWM grayscale (GS) steps. Also, each color group can be controlled by 128 constant-current sink steps with the global brightness control (BC) function. GS control and BC are accessible via a two-wire signal interface. The maximum current value for each channel is set by a single external resistor. All constant-current outputs are turned off when the IC is in an over-temperature condition.
评论(0)
发评论
下载排行榜
