MAX5463, MAX5464, MAX5465 pdf
消耗积分:2 | 格式:rar | 大小:666 | 2008-10-01
张强
分享资料个
The MAX5460–MAX5468 linear-taper digital potentiometers
perform the same function as a mechanical potentiometer
or a variable resistor. These devices consist of a
fixed resistor and a wiper contact with 32-tap points that
are digitally controlled through a 2-wire serial interface.
The MAX5462/MAX5465/MAX5468 are configured as
potentiometers. The rest of the devices in this family are
configured as variable resistors. See Pin Configurations
for part functionality.
Three resistance values are available: 10kΩ (MAX5466/
MAX5467/MAX5468), 50kΩ (MAX5463/MAX5464/
MAX5465), and 100kΩ (MAX5460/MAX5461/MAX5462).
The MAX5460–MAX5465 (100kΩ and 50kΩ) are available
in space-saving 5-pin and 6-pin SC70 packages.
The MAX5466/MAX5467/MAX5468 (10kΩ) are available
in 5-pin and 6-pin SOT23 packages.
Applications
LCD Screen Adjustment
Volume Control
Mechanical Potentiometer Replacement
Gain Adjustment
Line Impedance Matching
评论(0)
发评论
下载排行榜
