RT9301/DS9301 pdf datasheet (3
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-11
分享资料个
The RT9301 is a 3-Channel current source driver for RGB
LED. It is easy to be designed in applications that need
mixing RGB light source for multi-color output.
The RT9301 also provide users with great flexibility and
device performance. It uses a external resistor to set the
bias current for three LEDs, which are matched to 3%.
Users can adjust the output current from 2mA to 50mA by
setting the ISET resistor.
The RT9301 features very low dropout and under voltage
lockout protection. It is available in a space-saving TSOT-
23-8 package.
评论(0)
发评论
下载排行榜
