MAX2741 pdf datasheet (Integra
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-13
安德森大
分享资料个
The MAX2741 L1-band GPS receiver IC offers a highperformance,
compact solution for mobile handsets,
PDAs, and automotive applications. Total voltage gain
of 80dB and a 4.7dB cascaded noise figure can provide
receiver sensitivity for applications requiring
-185dBW for indoor tracking solutions.
This dual-conversion receiver downconverts the
1575.42MHz GPS signal to a 37.38MHz first IF, and then
a 3.78MHz second IF. An integrated 2- or 3-bit ADC (1-
bit SIGN, 1- or 2-bit MAG selectable) samples the second
IF and outputs the digitized signals to the baseband
processor.
The integrated synthesizer offers the flexibility in frequency
planning to allow a single board design to be
employed for reference frequencies from 2MHz to
26MHz. The integrated reference oscillator allows either
TCXO or crystal operation.
The receiver runs from a 2.7V to 3.0V supply, and draws
only 30mA when active. It is offered in a 28-pin thin QFN
package, and is specified for -40°C to +85°C at 3V.
评论(0)
发评论
下载排行榜
