TDA9981B pdf datasheet
消耗积分:3 | 格式:rar | 大小:195 | 2008-12-20
刘艳
分享资料个
HDMI transmitter up to 150 MHz pixel rate with 3 ´ 8-bit video inputs and 4 ´ I2S-bus with S/PDIF
The TDA9981B is an HDMI transmitter (which also supports DVI) that enables a 3 ´ 8-bit
RGB or YCbCr video stream (with a pixel rate up to 150 MHz for the TDA9981BHL/15
version), up to 4 I2S-bus audio streams (with an audio sampling rate up to 192 kHz) and
the additional information required by all the HDMI 1.2a standards.
In order to be compatible with most applications, the TDA9981B integrates a full
programmable input formatter and color space conversion block. The video input formats
accepted are YCbCr 4 : 4 : 4 (up to 3 ´ 8-bit), YCbCr 4 : 2 : 2 semi-planar (up to
2 ´ 12-bit), YCbCr 4 : 2 : 2 compliant with ITU656 and ITU656-like (up to 1 ´ 12-bit).
For ITU656-like formats, double edges are supported so that data can be sampled on
rising and falling edges.
The device can be controlled via an I2C-bus interface.
评论(0)
发评论
下载排行榜
