EL6296 pdf datasheet (Laser Di
消耗积分:3 | 格式:rar | 大小:666 | 2009-01-16
王树林
分享资料个
The EL6296 is a highly integrated
laser diode driver designed to support
multi-standard writable optical drives.
It accomplishes this by incorporating a waveform generator
wherein the diode currents and timing details can be
programmed before operation. The data input circuitry
inspects the NRZ serial data waveform and generates
programmed waveforms in recognition of 3, 4, 5, or 6 or
more clock periods of space changing to 3, 4, 5, or 6 or more
clock periods of mark, and vice versa.
This programmable architecture allows reprogramming of
the timers to support different media, DVD or CD standards,
and different speeds. The programming is accomplished
through a serial interface port. Two outputs are provided to
support dual-laser multi-standard optical heads.
The EL6296 requires 3.3V and 5V supplies, with all the
logical interface operating on the 3.3V supply.
评论(0)
发评论
下载排行榜
