EL2030 pdf datasheet (120MHz C
消耗积分:2 | 格式:rar | 大小:333 | 2009-01-17
梅利号
分享资料个
The EL2030 is a very fast, wide
bandwidth amplifier optimized for
gains between -10 and +10. Built using
the Elantec monolithic Complementary Bipolar process, this
amplifier uses current mode feedback to achieve more
bandwidth at a given gain than a conventional voltage
feedback operational amplifier.
Due to its wide operating supply range (±15V) and extremely
high slew rate of 2000V/μs, the EL2030 drives ±10V into
200Ω at a frequency of 30MHz, while achieving 110MHz of
small signal bandwidth at AV = +2. This bandwidth is still
95MHz for a gain of +10. On ±5V supplies the amplifier
maintains a 90MHz bandwidth for AV = +2. When used as a
unity gain buffer, the EL2030 has a 120MHz bandwidth with
the gain precision and low distortion of closed loop buffers.
The EL2030 features extremely low differential gain and
phase, a low noise topology that reduces noise by a factor of
2 over competing amplifiers, and settling time of 40ns to
0.25% for a 10V step. The output is short circuit protected. In
addition, datasheet limits are guaranteed for ±5V and ±15V
supplies.
Elantec's products and facilities comply with applicable
quality specifications. See Elantec document, QRA-1:
Processing, Monolithic Integrated Circuits.
评论(0)
发评论
下载排行榜
