ADP1048 pdf datasheet (Digital Power Factor Correction Controller)
消耗积分:0 | 格式:pdf | 大小:1733 KB | 2011-11-26
dplion
分享资料个
The ADP1047/ADP1048 are digital power factor correction (PFC) controllers that provide accurate input power metering capability and inrush current control for ac/dc systems. The ADP1047 is designed for single phase PFC applications; the ADP1048 is designed especially for interleaved and bridgeless PFC applications.
The digital PFC function is based on a conventional boost PFC with multiplication of the output voltage feedback combined with the input current and voltage to provide optimum harmonic correction and power factor for ac/dc systems. All signals are converted into the digital domain to provide maximum flexibility; all key parameters can be reported and adjusted via the PMBus™ interface. The ADP1047/ADP1048 allow users to optimize system performance, maximize efficiency across the load range, and reduce design time to market.
The ADP1047/ADP1048 provide accurate rms measurement of input voltage, current, and power. This information can be reported to the microcontroller of the power supply via the PMBus interface.
APPLICATIONS
AC/DC power supplies for applications
- Computing Server & Storage
- Network and communication infrastructure
- Industrial and Medical
评论(0)
发评论
下载排行榜
