Logger iButton devices have gained a lot of popularity with researchers. Although free evaluation software is easy to use and welldocumented, the choices and inputs that need to be made can sometimes be challenging. This application note explains technicalterms that are common with temperature logger iButtons and how they relate to each other. Additionally, it presents an algorithm tohelp users choose the necessary input parameters, including the sample rate based on a user's needs and the available memory tostore the data.
