MAX4607-MAX4609数据资料PDF
消耗积分:0 | 格式:pdf | 大小:142 KB | 2012-11-06
分享资料个
The MAX4607/MAX4608/MAX4609 dual analog switchesfeature low on-resistance of 2.5Ω max. On-resistance ismatched between switches to 0.5Ω max and is flat (0.5Ωmax) over the specified signal range. Each switch canhandle rail-to-rail analog signals. The off-leakage currentis only 2.5nA max at +85°C. These analog switches areideal in low-distortion applications and are the preferredsolution overmechanical relays in automatic test equipmentor applications where current switching is required.They have low power requirements, require less boardspace, and are more reliable than mechanical relays.
评论(0)
发评论
下载排行榜
