MAX1757数据资料
消耗积分:0 | 格式:pdf | 大小:170 KB | 2013-04-23
分享资料个
The MAX1757 is a switch-mode lithium-ion (Li+) batterycharger that charges one to three cells. It provides aregulated charging current accurate to ±10% and aregulated voltage with only a ±0.8% total voltage errorat the battery terminals. The internal high-side switchdelivers a programmable current of up to 1.5A tocharge the battery. The built-in safety timer automaticallyterminates charging once the adjustable time limithas been reached.
评论(0)
发评论
下载排行榜
