基于多信息融合算法提高传感器稳定性
消耗积分:3 | 格式:rar | 大小:83 | 2009-06-19
526774
分享资料个
该文提出了改善传感器测量稳定性的一种新方法。该方法的基本思路是将影响传
感器输出稳定性的因子作为传感器融合系统的输入模式,基于系统辨识理论实现融合算法。实验结果表明该方法有效地抑制非目标参量的干扰,获得高稳定性测量结果。
[关键词]  传感器;数据融合;稳定性;多信息
  Abstract :A new method to enhance the stability of a sensor is presented. Its basic thought is that the fac2 tor to affect the stability of the sensor is made as an input sensor of the sensor fusion system. The fusion algo2 rithm is achieved based on the system identification. Experiment results show the method is effective.
  Key words :Sensor ;Dats fusion ;Stability ;Multi2information
评论(0)
发评论
下载排行榜
