These devices consist of two independent low voltage comparators designed specifically to operate from a single supply over a wide range of voltages。Operation from split power supplies is also possible。These comparators also have a unique characteristic in that the input common-mode voltage range includes ground even though operated from a single power supply voltage.。资料很好,很全面。
