firecomms最新发布520nm绿光收发器
消耗积分:0 | 格式:pdf | 大小:807KB | 2014-08-31
boriszhao
分享资料个
Firecomms发布的520nm绿光收发器在塑料光纤中可以可靠传输200米.
RedLink devices are color coded, FT01MHNG transmitters are green and receivers are blue. They are auto-insertable. They are tested for handling in static controlled assembly processes (HBM and CDM). Cleaning, degreasing and post solder washing should be carried out using standard solutions compatible with both plastics and the environment. For example, recommended solutions for degreasing are alcohols, (methyl, isopropyl and isobutyl). In the soldering process, non-halogenated water soluble fluxes are recommended. RedLink products are not suitable for use in reflow solder processes (infrared/vapor- phase reflow). The dust plug should be kept in place during soldering, washing and drying processes to avoid contamination of the active optical area of each connector.
评论(0)
发评论
下载排行榜
