SGM3204 Unregulated 200mA Charge Pump Voltage Inverter
消耗积分:0 | 格式:pdf | 大小:298KB | 2014-09-19
龙建明
分享资料个
The SGM3204 generates an unregulated negative output  voltage from an input voltage ranging from 1.4V to 5.5V。The device is typically supplied by a pre-regulated supply rail of 5V or 3.3V. Due to its wide input voltage range,two or three NiCd,NiMH, or alkaline battery cells, as well as one Li-ion cell can also power them。
评论(3)
发评论
LIAOYUWEN 2018-06-08
0 回复 举报
谢谢 收起回复
luomengde 2018-03-20
0 回复 举报
谢谢楼主 收起回复
全部评论
下载排行榜
全部3条评论
