DRV8811,pdf datasheet (Stepper
消耗积分:5 | 格式:rar | 大小:433 | 2009-07-30
远不及你
分享资料个
The DRV8811 provides an integrated stepper motor driver solution for printers, scanners, and other automated equipment applications. The device has two H-bridge drivers, as well as microstepping indexer logic to control a stepper motor.
The output driver block for each consists of N-channel power MOSFETs configured as full H-bridges to drive the motor windings.
A simple step/direction interface allows easy interfacing to controller circuits. Pins allow configuration of the motor in full-step, half-step, quarter-step, or eighth-step modes. Decay mode and PWM off time are programmable.
Internal shutdown functions are provided for over current protection, short circuit protection, under-voltage lockout and overtemperature.
The DRV8811 is packaged in a PowerPAD 28-pin HTSSOP package with thermal pad (Eco-friendly: RoHS and no Sb/Br).
评论(0)
发评论
下载排行榜
