AD9752,pdf datasheet (TxDAC D/
消耗积分:3 | 格式:rar | 大小:510 | 2009-09-21
分享资料个
The AD9752 is a current-output DAC with a nominal full-scale
output current of 20 mA and > 100 kW output impedance.
Differential current outputs are provided to support singleended
or differential applications. Matching between the two
current outputs ensures enhanced dynamic performance in a
differential output configuration. The current outputs may be
tied directly to an output resistor to provide two complementary,
single-ended voltage outputs or fed directly into a transformer.
The output voltage compliance range is 1.25 V.
评论(0)
发评论
下载排行榜
