ADG3301,pdf datasheet (Bidirec
消耗积分:3 | 格式:rar | 大小:551 | 2009-09-25
分享资料个
The ADG3301 is a single-channel, bidirectional logic level translator. It can be used in multivoltage digital system applica-tions such as data transfer between a low voltage DSP/controller and a higher voltage device. The internal architecture allows the device to perform bidirectional logic level translation without an additional signal to set the direction in which the translation takes place.
评论(0)
发评论
下载排行榜
