ADG3248 ,pdf datasheet (Demult
消耗积分:3 | 格式:rar | 大小:551 | 2009-09-25
overheat
分享资料个
The ADG3248 is a 2.5 V or 3.3 V, high performance 2:1
multiplexer/demultiplexer. It is designed on a low voltage CMOS process, which provides low power dissipation yet gives
high switching speed and very low on resistance. The low on resistance allows the input to be connected to the output without additional propagation delay or generating additional
ground bounce noise.
评论(0)
发评论
下载排行榜
