LM2660/LM2661,pdf datasheet (S
消耗积分:3 | 格式:rar | 大小:565 | 2009-09-29
h1654155275.0032
分享资料个
The LM2660/LM2661 CMOS charge-pump voltage converter
inverts a positive voltage in the range of 1.5V to 5.5V
to the corresponding negative voltage. The LM2660/LM2661
uses two low cost capacitors to provide 100 mA of output
current without the cost, size, and EMI related to inductor
based converters. With an operating current of only 120 μA
and operating efficiency greater than 90% at most loads, the
LM2660/LM2661 provides ideal performance for battery
powered systems. The LM2660/LM2661 may also be used
as a positive voltage doubler.
评论(0)
发评论
下载排行榜
