LM9036,pdf datasheet (Ultra-Lo
消耗积分:3 | 格式:rar | 大小:555 | 2009-10-05
手托初梦
分享资料个
The LM9036 ultra-low quiescent current regulator features
low dropout voltage and low current in the standby mode. With
less than 25μA Ground Pin current at a 0.1mA load, the
LM9036 is ideally suited for automotive and other battery operated
systems. The LM9036 retains all of the features that
are common to low dropout regulators including a low dropout
PNP pass device, short circuit protection, reverse battery protection,
and thermal shutdown. The LM9036 has a 40V maximum
operating voltage limit, a −40°C to +125°C operating
temperature range, and ±5% output voltage tolerance over
the entire output current, input voltage, and temperature
range.
评论(0)
发评论
下载排行榜
