LM78L12,pdf datasheet (3-Termi
消耗积分:5 | 格式:rar | 大小:554 | 2009-10-05
打马过草原
分享资料个
The LM78LXX series of three terminal positive regulators is
available with several fixed output voltages making them
useful in a wide range of applications. When used as a zener
diode/resistor combination replacement, the LM78LXX usually
results in an effective output impedance improvement of
two orders of magnitude, and lower quiescent current. These
regulators can provide local on card regulation, eliminating
the distribution problems associated with single point regulation.
The voltages available allow the LM78LXX to be used
in logic systems, instrumentation, HiFi, and other solid state
electronic equipment.
评论(0)
发评论
下载排行榜
