LP5951,pdf datasheet (Micropow
消耗积分:3 | 格式:rar | 大小:552 | 2009-10-05
479809
分享资料个
The LP5951 regulator is designed to meet the requirements
of portable, battery-powered systems providing a regulated
output voltage and low quiescent current. When switched to
shutdown mode via a logic signal at the Enable pin, the power
consumption is reduced to virtually zero.
评论(0)
发评论
下载排行榜
