DAC0800/DAC0802,pdf datasheet
消耗积分:5 | 格式:rar | 大小:556 | 2009-10-12
分享资料个
The DAC0800 series are monolithic 8-bit high-speed
current-output digital-to-analog converters (DAC) featuring
typical settling times of 100 ns. When used as a multiplying
DAC, monotonic performance over a 40 to 1 reference current
range is possible. The DAC0800 series also features
high compliance complementary current outputs to allow
differential output voltages of 20 Vp-p with simple resistor
loads. The reference-to-full-scale current matching of better
than ±1 LSB eliminates the need for full-scale trims in most
applications, while the nonlinearities of better than ±0.1%
over temperature minimizes system error accumulations.
评论(0)
发评论
下载排行榜
