DS90LV032A,pdf datasheet (3V L
消耗积分:3 | 格式:rar | 大小:556 | 2009-10-13
分享资料个
The DS90LV032A is a quad CMOS differential line receiver
designed for applications requiring ultra low power dissipation
and high data rates. The device is designed to support
data rates in excess of 400 Mbps (200 MHz) utilizing Low
Voltage Differential Signaling (LVDS) technology.
The DS90LV032A accepts low voltage (350 mV typical) differential
input signals and translates them to 3V CMOS output
levels. The receiver supports a TRI-STATE® function that
may be used to multiplex outputs. The receiver also supports
open, shorted and terminated (100W) input Fail-safe. The receiver
output will be HIGH for all fail-safe conditions.
The DS90LV032A and companion LVDS line driver (eg.
DS90LV031A) provide a new alternative to high power
PECL/ECL devices for high speed point-to-point interface
applications.
评论(0)
发评论
下载排行榜
