ADV7623,pdf,datasheet(HDMI 1.4
消耗积分:10 | 格式:rar | 大小:444 | 2009-10-15
李娟
分享资料个
ADV7623 is a high performance 4 input, 1 output, High-Definition Multimedia Interface (HDMI™) transceiver that integrates HDMI receiver and transmitter with digital audio inputs and outputs onto one chip. It supports all HDCP repeater functions through fully tested ADI repeater software libraries and drivers.
The ADV7623 incorporates Xpressview™ fast switching on all input HDMI ports. Using the Analog Devices hardware-based HDCP engine that minimizes software overhead, Xpressview allows fast switching between any HDMI input ports in less than 1 second.
The ADV7623 supports all mandatory 3D TV formats in addition to all HDTV formats up to 1080p, 12-bit Deep Color. The ADV7623 also integrates an HDMI v1.4 CEC controller that supports the capability discovery and control (CDC) feature.
The ADV7623 has an integrated on-screen display (OSD) feature that allows generation and control of high quality character- and icon-based system status and control displays. Customers interested in using the OSD feature can make use of the Analog Devices OSD software development kit.
The ADV7623 offers a dedicated flexible audio output port and a dedicated audio input port to allow easy extraction and insertion of audio data into and out of the HDMI stream. All HDMI audio formats, including super audio CD (SACD) via DSD, compressed SACD via DST, and HBR, are supported. The ADV7623 also features an audio return channel (ARC) receiver. ARC simplifies cabling by combining upstream audio capability in a conventional HDMI cable.
Fabricated in an advanced CMOS process, the ADV7623 is provided in a 144-lead, 20 mm × 20 mm, Pb-free LQFP package and is specified over the −20°C to +70°C temperature range.
评论(2)
发评论
欧姆电子 2012-09-11
0 回复 举报
骗子,这也叫做资料???就那么一页。 收起回复
2011-06-08
0 回复 举报
这好的资料什么下载啊??
管理员回复: 感谢您的反馈,现在已经修复了 可以下载了
收起回复
下载排行榜
全部2条评论
