LM61,datasheet,pdf(2.7V, SOT-2
消耗积分:2 | 格式:rar | 大小:554 | 2009-10-20
KANA
分享资料个
The LM61 is a precision integrated-circuit temperature sensor
that can sense a −30°C to +100°C temperature range
while operating from a single +2.7V supply. The LM61’s
output voltage is linearly proportional to Celsius (Centigrade)
temperature (+10 mV/°C) and has a DC offset of +600 mV.
The offset allows reading negative temperatures without the
need for a negative supply. The nominal output voltage of the
LM61 ranges from +300 mV to +1600 mV for a −30°C to
+100°C temperature range. The LM61 is calibrated to provide
accuracies of ±2.0°C at room temperature and ±3°C
over the full −25°C to +85°C temperature range.
评论(0)
发评论
下载排行榜
