ADG1436,pdf datasheet ( 1.5 Ω
消耗积分:3 | 格式:rar | 大小:557 | 2009-10-27
自我清欢
分享资料个
The ADG1436 is a monolithic CMOS device containing two independently selectable SPDT switches. An EN input on the LFCSP package is used to enable or disable the device. When disabled, all channels are switched off. Each switch conducts equally well in both directions when on and has an input signal range that extends to the supplies. In the off condition,
评论(0)
发评论
下载排行榜
