8-bit I2C-bus and SMBus IO port with reset
消耗积分:5 | 格式:rar | 大小:224 | 2009-11-10
贾永世
分享资料个
The PCA9557 is a silicon CMOS circuit which provides parallel input/output expansion for
SMBus and I2C-bus applications. The PCA9557 consists of an 8-bit input port register,
8-bit output port register, and an I2C-bus/SMBus interface. It has low current consumption
and a high-impedance open-drain output pin, IO0.
The system master can enable the PCA9557’s I/O as either input or output by writing to
the configuration register. The system master can also invert the PCA9557 inputs by
writing to the active HIGH polarity inversion register. Finally, the system master can reset
the PCA9557 in the event of a time-out by asserting a LOW in the reset input.
The power-on reset puts the registers in their default state and initializes the
I2C-bus/SMBus state machine. The RESET pin causes the same reset/initialization to
occur without de-powering the part.
评论(0)
发评论
下载排行榜
