Description The TS914 device is a rail-to-rail CMOS quad operational amplifier designed to operate with a single or dual supply voltage. The input voltage range Vicm includes the two supply rails VCC+ and VCC-。 The output reaches VCC- +50 mV, VCC+ -50 mV, with RL = 10 kΩ, and VCC- +350 mV, VCC+ - 350 mV, with RL = 600 Ω。 This product offers a broad supply voltage operating range from 2.7 to 16 V and a supply current of only 200 μA/amp. (VCC = 3 V)。 The source and sink output current capability is typically 40 mA (at VCC = 3 V), fixed by an internal limitation circuit.
