Achieving Timing Closure:Timing Reports • Timing reports enable you to determine how and why constraints were not met – Reports contain detailed descriptions of paths that fail their constraints • The Project Navigator can create timing reports at two points in the design flow – Post-Map Static Timing Report – Post-Place & Route Static Timing Report • The Timing Analyzer is a utility for creating and reading timing reports PDF created
