74LS125/54LS125A pdf datasheet
消耗积分:3 | 格式:rar | 大小:133 | 2008-08-06
分享资料个
54LS125A/DM54LS125A/DM74LS125A
Quad TRI-STATEÉ Buffers
General Description
This device contains four independent gates each of which
performs a non-inverting buffer function. The outputs have
the TRI-STATE feature. When enabled, the outputs exhibit
the low impedance characteristics of a standard LS output
with additional drive capability to permit the driving of bus
lines without external resistors. When disabled, both the
output transistors are turned off presenting a high-impedance
state to the bus line. Thus the output will act neither as
a significant load nor as a driver. To minimize the possibility
that two outputs will attempt to take a common bus to opposite
logic levels, the disable time is shorter than the enable
time of the outputs.
Features
Y Alternate Military/Aerospace device (54LS125) is available.
Contact a National Semiconductor Sales Office/
Distributor for specifications.
评论(0)
发评论
下载排行榜
