ICE2A0565 pdf datasheet
消耗积分:10 | 格式:rar | 大小:555 | 2008-08-06
分享资料个
CoolSET™-F2
ICE2A0565/165/265/365
ICE2B0565/165/265/365
ICE2A0565G
ICE2A0565Z
ICE2A180Z/280Z
ICE2A765I/2B765I
ICE2A765P2/2B765P2
Off-Line SMPS Current Mode
Controller with integrated 650V/
800V CoolMOS™
The second generation CoolSET™-F2 provides several
special enhancements to satisfy the needs for low power
standby and protection features. In standby mode
frequency reduction is used to lower the power
consumption and support a stable output voltage in this
mode. The frequency reduction is limited to 20kHz/21.5
kHz to avoid audible noise. In case of failure modes like
open loop, overvoltage or overload due to short circuit the
device switches in Auto Restart Mode which is controlled by
the internal protection unit. By means of the internal precise
peak current limitation, the dimension of the transformer
and the secondary diode can be sized lower which leads to
more cost effective for the overall system.
评论(0)
发评论
下载排行榜
