Applications
• Commercial and Military Radar
• Electronic Warfare
• Satellite Communications
• Point to Point Radio
• General Purpose
General Description
Pad Configuration Qorvo’s TGL2226 is a wideband, 6-bit digital attenuator fabricated using Qorvo‘s production 0.15um GaAs pHEMT process (QPHT15)。 Operating from 0.1– 15 GHz, the TGL2226 offers a low LSB of 0.5 dB and supports 31.5 dB of attenuation range with a low insertion loss from 2.8–3.8 dB over frequency and a low RMS attenuation error of less than 2.0 dB.
Using standard, negative control voltages from −3.0 V to −5.0 V, coupled with excellent broadband performance, the TGA2226 is ideal for supporting a variety of commercial and military applications. The TGL2226 is in die form, 1.180 x 1.000 x 0.100 mm, with both RF ports matched to 50 ohms for simple system integration.
Lead-free and RoHS compliant.
Evaluation Boards available on request.
