AIC1190 datasheet,pdf(Ultra LD
消耗积分:5 | 格式:rar | 大小:818 | 2010-03-22
KANA
分享资料个
AIC1190 datasheet,pdf(Ultra LDO 1A Linear Regulator With Adjustable & Bypass Pin)
A low noise, high PSRR and ultra low dropout
linear regulator AIC1190 is optimized for low ESR
ceramic capacitors operation with 1A continuous
current.
The AIC1190 offers high precision output voltage
of ±2% tolerance. Output voltage can also be
adjusted for those other than the preset values.
评论(0)
发评论
下载排行榜
