NLSF595 pdf,datasheet
Serial (SPI) Tri−Color LED Driver
The NLSF595 is advanced CMOS shift register with open drain
outputs fabricated with 0.6 m silicon gate CMOS technology. This
device is used in conjunction with a microcontroller, with only one
dedicated line. All pins have Overvoltage Protection that allows
voltages above VCC up to 7.0 V to be present on the pins without
damage or disruption of operation of the part, regardless of the
operating voltage. This device may be used between 2.0 and 5.5 volts,
the output driver level may be independent of supply voltage:
0−7.0 volts.
