The MAX14544/MAX14545 are overcurrent detection switches that can provide power to external accessories while preventing the host device from damage due to faulty overload conditions. These analog switches feature a 270mω (typ) on-resistance and operate from a +2.3V to +5.5V input voltage range. The selectable current limit of 200mA or 400mA makes them ideal for load-switching applications. The MAX14544 has an autoretry feature, whereas the MAX14545 has a latchoff feature. When the switch is off, OUT can withstand 28V maximum. When the switch is on and a load is connected to the port, a blanking time of 10.5ms ensures that the transient voltage settles down. After this blanking time, if the voltage across the switch is greater than the FLAG assertion voltage, the switch turns off and then a FLAG is issued to the microprocessor. After the retry time, the device recloses for the duration of the blanking time to check if the load current is lower than the limit. The MAX14544 repeats this cycle if the overload condition is present. During the cycle, FLAG remains asserted. The MAX14544 remains on after the overload condition is removed and FLAG deasserts. For the MAX14545, after the blanking time, the switch turns off and then a FLAG is issued to the microprocessor. The switch can be turned on again by cycling the power or the EN input.
