DLPC100,pdf
消耗积分:5 | 格式:rar | 大小:508 | 2010-06-01
李丽
分享资料个
The DLPC100 performs all the image processing and control, along with DMD data formatting, for driving a 0.17 HVGA DMD (DLP1700).
The DLPC100 is one of three components in the 0.17 HVGA Chipset (see Figure 1). Proper function and operation of the DLP1700 requires that it be used in conjunction with the other components of the 0.17 HVGA Chip-Set. Refer to the 0.17 HVGA Chip-Set Data Sheet for further details (TI literature number DLPS017).
In DLP electronics solutions, image data is 100% digital from the DLPC100 input port to the image projected on to the display screen. The image stays in digital form and is never converted into an analog signal. The DLPC100 processes the digital input image and converts the data into a format needed by the DMD.
评论(0)
发评论
下载排行榜
