DLPC200,pdf
消耗积分:5 | 格式:rar | 大小:900 | 2010-06-01
王兰
分享资料个
The DLPC200 performs image processing and control, along with DMD data formatting, for driving a 0.55 XGA DMD (DLP5500).
The DLPC200 is one of three components in the 0.55 XGA Chipset (see Figure 1). Proper function and operation of the DLP5500 requires that it be used in conjunction with the other components of the 0.55 XGA Chip-Set. Refer to the 0.55 XGA Chip-Set Data Sheet for further details (TI literature number DLPS012).
In DLP electronics solutions, image data is 100% digital from the DLPC200 input port to the image projected on to the display screen. The image stays in digital form and is never converted into an analog signal. The DLPC200 processes the digital input image and converts the data into a format needed by the DMD.
评论(0)
发评论
下载排行榜
