ADS5237pdf(Dual 10-Bit 65MS
消耗积分:3 | 格式:rar | 大小:1176 | 2010-06-07
张虎豹
分享资料个
The ADS5237 is a dual, high-speed, high dynamic range, 10-bit, pipelined analog-to-digital converter (ADC). This device includes a high-bandwidth sample-and-hold amplifier that gives excellent spurious performance up to and beyond the Nyquist rate. The differential nature of the sample-and-hold amplifier and ADC circuitry minimizes even-order harmonics and gives excellent common-mode noise immunity.
The ADS5237 provides for setting the full-scale range of the converter without any external reference circuitry. The internal reference can be disabled, allowing low-drive, external references to be used for improved tracking in multichannel systems.
The ADS5237 provides an over-range indicator flag to indicate an input signal that exceeds the full-scale input range of the converter.
评论(0)
发评论
下载排行榜
