PCM3060PDF(24-Bit 96/192 kHz
消耗积分:5 | 格式:rar | 大小:726 | 2010-06-13
杨平
分享资料个
The PCM3060 is a low-cost, high-performance, single-chip, 24-bit stereo audio codec with single-ended analog inputs and differential analog outputs.
The stereo 24-bit ADC employs a 64-times delta-sigma modulator. It supports 16-96 kHz sampling rates and a 16/24-bit digital audio output word on the audio interface.
The stereo 24-bit DAC employs a 64- or 128-times delta-sigma modulator. It supports 16-192 kHz sampling rates and a 16/24-bit digital audio input word on the audio interface.
The PCM3060 supports fully independent operation of the sampling rate and audio interface for the ADC and DAC.
Each audio interface supports I2S, left-justified, and right-justified formats with 16/24-bit words.
The PCM3060 can be software-controlled through a 3-wire SPI-compatible or 2-wire I2C-compatible serial interface, which provides access to all functions including digital attenuation, soft mute, de-emphasis etc.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
