SN74HC4851/SN74HC4852 Product
消耗积分:5 | 格式:rar | 大小:501 | 2010-07-09
申换换
分享资料个
Texas Instruments’ (TI) SN74HC4851/HC4852, analog
multiplexer/demultiplexer (mux/demux) device is pin
compatible with the 4051/4052 function. The HC4851/
HC4852 also offers injection current protection, which
makes it an ideal solution in harsh environments such as
automotive, where voltage spikes in excess of
normal logic voltage levels are common. The injection
current effect control circuitry eliminates the need for
external diode/resistor networks typically used to keep
the analog channel signals within the supply voltage
range. TI offers the HC4851/HC4852 in a variety of pack-
age options: PDIP, SOIC, TSSOP and TVSOP.
评论(0)
发评论
下载排行榜
