SN54LV05A, SN74LV05A,pdf(HEX I
消耗积分:3 | 格式:rar | 大小:477 | 2010-07-13
分享资料个
The ’LV05A devices contain six independent inverters designed for 2-V to 5.5-V VCC operation.
These devices perform the Boolean function Y = A\.
The open-drain outputs require pullup resistors to perform correctly and can be connected to other open-drain outputs to implement active-low wired-OR or active-high wired-AND functions.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
