The 'ACT16825 18-bit buffers/drivers are designed specifically to improve both the performance and density of 3-state memory address drivers, clock drivers, and bus-oriented receivers and transmitters.
The 'ACT16825 can be used as two 9-bit buffers or one 18-bit buffer. They provide true data from A to Y.
The 3-state control gate is a 2-input NOR gate; therefore, if either output-enable (
or
) input is high, all nine affected outputs are in the high-impedance state.
The 74ACT16825 is packaged in TI's shrink small-outline package, which provides twice the I/O pin count and functionality of standard small-outline packages in the same printed-circuit-board area.
The 54ACT16825 is characterized for operation over the full military temperature range of -55°C to 125°C.
