SN54LV595A,SN74LV595A,pdf(8-Bi
消耗积分:5 | 格式:rar | 大小:813 | 2010-08-04
分享资料个
The ’LV595A devices are 8-bit shift registers designed for 2-V to 5.5-V VCC operation.
These devices contain an 8-bit serial-in, parallel-out shift register that feeds an 8-bit D-type storage register. The storage register has parallel 3-state outputs. Separate clocks are provided for both the shift and storage register. The shift register has a direct overriding clear (SRCLR)\ input, serial (SER) input, and a serial output for cascading. When the output-enable (OE)\ input is high, all outputs except QH’ are in the high-impedance state.
Both the shift register clock (SRCLK) and storage register clock (RCLK) are positive-edge triggered. If both clocks are connected together, the shift register always is one clock pulse ahead of the storage register.
评论(0)
发评论
下载排行榜
