SN74CBTS3384,pdf(10-BIT FET BU
消耗积分:2 | 格式:rar | 大小:510 | 2010-08-17
分享资料个
The SN74CBTS3384 provides ten bits of high-speed TTL-compatible bus switching with Schottky diodes on the I/Os to clamp undershoot. The low on-state resistance of the switch allows connections to be made with minimal propagation delay.
The device is organized as two 5-bit bus switches with separate output-enable (OE\) inputs. When OE\ is low, the switch is on, and port A is connected to port B. When OE\ is high, the switch is open, and the high-impedance state exists between the two ports.
评论(0)
发评论
下载排行榜
