OPA356-Q1,pdf(200-MHz CMOS OPE
消耗积分:3 | 格式:rar | 大小:574 | 2010-09-12
分享资料个
The OPA356 is a high-speed voltage-feedback CMOS operational amplifier designed for video and other applications requiring wide bandwidth. The OPA356 is unity gain stable and can drive large output currents. Differential gain is 0.02% and differential phase is 0.05°. Quiescent current is only 8.3 mA.
OPA356 is optimized for operation on single or dual supplies as low as 2.5 V (±1.25 V) and up to 5.5 V (±2.75 V). Common-mode input range for the OPA356 extends 100 mV below ground and up to 1.5 V from V+. The output swing is within 100 mV of the rails, supporting wide dynamic range.
The OPA356 is available in the SOT23-5 package and is specified over the –40°C to 125°C range.
评论(0)
发评论
下载排行榜
